Vacuum lock system and Very hot wire
burnerofhells
Copper - Posts: 57
Posted: January 20, 2004 at 9:56 PM / IP Logged
I finally got my keyless entry to work in my 1993 VW jetta but i noticed that if I lock and unlock the car multiple times in a row (4 or more) the wire that goes to the lock switch part, from the brain, is getting very hot.  Is this normal when the car is locked/unlocked repeatedly?
Since it is a vacuum lock sytem it uses a 4 second pulse, could this be the reason?  Should i worry about this?
It is the wire from terminal 87a of the extermal relay that is gettin hot.  Check it out below.
https://images.cardomain.com/member_images/5/web/185000-185999/185158_107_full.gif
burnerofhells
Copper - Posts: 57
Posted: January 20, 2004 at 10:05 PM / IP Logged
the wire from the vacuum pump to the door switches i used was the RED / black wire.
OK i just realized something... it doesnt matter how many times i unlock/lock the doors the wire is just getting really hot like power wont stop running through the wire. I disconnected it in fear of fires.  What may the problem be?
Platinum - Posts: 12,488
Posted: January 21, 2004 at 1:41 AM / IP Logged
What wire colors did you use and where in the car did you tap the keyless entry wires to ?
burnerofhells
Copper - Posts: 57
Posted: January 21, 2004 at 1:56 AM / IP Logged
I taped into the BLACK/ red wire right at the vacuum pump.  Sould i have done it at the drivers kick pannel?
why would it make a difference?
I noticed now that my driver door does not lock with the vacuum system anymore and has to be manually locked.  It turns out there is a resistor that got so hot it melted a hole in my drivers door lock.
Posted: January 21, 2004 at 2:06 AM / IP Logged
It's just the the wires at the switch would power a relay that would send a signal to the pump to activate the lock and unlock. According to some of the notes that i have, the Jetta uses a (+) trigger wire to activate the relays for the pump. You didn't have to go straight to the pump according to the wiring information that I have.
burnerofhells
Copper - Posts: 57
Posted: January 21, 2004 at 2:08 AM / IP Logged
But would going straight to the pump have caused this?
i am using a positive pulse
Posted: January 21, 2004 at 2:11 AM / IP Logged
On the diagram that you have, what is the " DOOR LOCK HARNESS " module suppose to be ? Is this on the car or is this the module that you have installed into the Jetta ?? I ask because all the other systems that I have installed into where I had to go tot he pump, I used 2 relays, not one.
burnerofhells
Copper - Posts: 57
Posted: January 21, 2004 at 2:44 AM / IP Logged
It is my ungo ms2004 alarm.
The diagram i have is what te install manual said to do.
How would i wire it up with 2 relays?
Keep in mind I must be a positive output.  Also that the wires coming off the DOOR LOCK HARNESS are the wires i have to work with from the alarm.
burnerofhells
Copper - Posts: 57
Posted: January 21, 2004 at 2:47 AM / IP Logged
Im pretty sure the alarm has one built in relay.  I think this is why all the wires coming off it are labeld like a realy.
Also It was the wire that goes to the door locks that got very hot.
Posted: January 21, 2004 at 9:30 AM / IP Logged
Vacuum Type Door Locks
