89 mazda mx6 pro 5005 combo
Welcome Guest :)
ricmar
Member -
Posted: November 26, 2003 at 3:16 PM / IP Logged
any help with wiring diagram for the mazda mx6 gt turbo 1989
ricmar
Member -
Posted: November 30, 2003 at 10:24 PM / IP Logged
need help with remote start wiring
ricmar
Member -
Posted: December 08, 2003 at 5:39 PM / IP Logged
need wire instaal book for pro series 5005 remote startalarm impulse series
TRiCk76
Member -
Posted: December 08, 2003 at 7:00 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #1: | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition #2: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | BLUE | IGNITION SWITCH HARNESS |
Brake Light: | | WHITE/ GREEN | (+) SWITCH ON BRAKE PEDAL BRACKET |
Tach Signal: | | YELLOW/BLUE | AT COIL OR AT TEST CONNECTOR * |
Parking Lights: | | WHITE/ GREEN | (+) AT LIGHT SWITCH OR AT FUSE BOX |
Headlights: | | RED / BLACK (LO) OR | RED / WHITE (HI) @ HEADLIGHT SWITCH (+) |
OEM Alarm Disarm: | | LIGHT GREEN/ BLACK | (-) DRIVER KICK PANEL |
OEM Alarm Arm: | | N/A | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Tach Test Connector Located On Driver Rear Corner Of Engine Compartment. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | BLACK | IGNITION SWITCH HARNESS |
Starter Kill: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | RED / WHITE | (-) AT PIN SWITCH OR AT FUSE BOX |
OEM Horn: | | GREEN/ ORANGE (-) | STEERING COLUMN HARNESS OR AT RELAY |
Power Lock: | | ADD ACTUATOR | IN DRIVER'S DOOR ** |
Power Unlock: | | ADD ACTUATOR | IN DRIVER'S DOOR ** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | RED / WHITE | (-) AT PIN SWITCH OR AT FUSE BOX |
Notes: | | ** See Note #204 - Adding Actuator Door Lock Diagram. |
ricmar
Member -
Posted: January 10, 2004 at 5:11 PM / IP Logged
i need the owners manual for pro 5005 alrm combo.mine came without any papers. richardmarinello@aol.com
ricmar
Member -
Posted: January 21, 2004 at 10:11 PM / IP Logged
i installed delta pro 5005 and it all seems to work.but after i start my car the first time each day it runs fine then the motor runs like crap and the check engine lite comes on.any help is welcome.
auex
Platinum -
Posted: January 21, 2004 at 10:15 PM / IP Logged
What kind of vehicle?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
RufNUSD
Copper -
Posted: January 21, 2004 at 10:16 PM / IP Logged
I have a feeling its a chevy or dodge truck.
Someone pass me that bottle.
ricmar
Member -
Posted: January 21, 2004 at 10:21 PM / IP Logged
auex
Platinum -
Posted: January 21, 2004 at 10:23 PM / IP Logged
Year?
Tuesday, March 24, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
