Aftermarket door lock actuators
phredman
Member - Posts: 24
Posted: January 26, 2004 at 2:07 PM / IP Logged
Does anyone have how to wiring for aftermarket doorlock actuators that have the one button feature ,such as the Spal kit ,whereas that if you push on the lock knob,it locks all doors,or if you pull up on the knob,it unlocks all doors.
The question is,how do you wire those for keyless entry and still have that feature? Thanks for any info for that....
bmf1000d
Silver - Posts: 345
Posted: January 26, 2004 at 5:59 PM / IP Logged
its a knob and not a rocker switch?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Bnluis
Silver - Posts: 578
Posted: January 26, 2004 at 6:05 PM / IP Logged
YES IT CAN BE DONE U WILL HAVE TO USE 2 RELAYS AND 5 WIRE  DOOR LOCK ACTUATORS.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
phredman
Member - Posts: 24
central locking kit
bmf1000d
Silver - Posts: 345
Posted: January 26, 2004 at 6:10 PM / IP Logged
so they are 5 wire door locks?
"Big" Mike
Double Take
Fremont, Ne
jacksonj
Member - Posts: 24
Posted: January 26, 2004 at 6:55 PM / IP Logged
From your question it sounds like you already have a Central locking system.  If this is the case then do as BNLUIS said
add 2 relays for a 5 wire door lock actuator  https://www.the12volt.com/doorlocks/page3.asp#arp
Just hook the Actuator to the drivers door lock in any method you can (depending on your car)
I'm doing this very same thing on my 2002 Elantra that has Central door locks.  The Elantra door locks are connected via a cable that I have to attach the actuator to.  Here the DIY for the Elantra, maybe the pics can assist you on your project. http://www.elantraxd.com/yabbse/index.php?board=21;action=display;threadid=5070;start=15
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
