Wiring Diagram for 04 Acura TL ?
TrueSound
Posted: January 26, 2004 at 6:41 PM / IP Logged
Does anyone have the info for the 04 TL? Doing an alarm remote start keyless on it. I'm hoping it's somewhat like the 04 Accord. . . . .
Thanks in advance
bmf1000d
Silver - Posts: 345
Posted: January 26, 2004 at 6:52 PM / IP Logged
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHITEIGNITION SWITCH HARNESS
IGNITION 1BLACK / YELLOWIGNITION SWITCH HARNESS
IGNITION 2YELLOWIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER WHITE/ BLACKIGNITION SWITCH HARNESS
STARTERBLACK/ WHITE IGNITION SWITCH HARNESS
KEYSENSERED / WHITE or     RED / BLACK ( - )IGNITION SWITCH HARNESS
PARKING LIGHTS ( + )RED / BLACK LARGE WHITE PLUG ABOVE FUSE BOX
DOMELIGHTGREEN/ RED ( - )GREEN 5 PIN PLUG BEHIND THE FUSE BOX
POWER DOOR LOCKPINK/BLACK ( - )IN GREEN PLUG LEFT SIDE OF  FUSE BOX
POWER DOOR UNLOCKPINK/BLUE  ( - ) (TYPE B)     *SEE NOTES* 1
TRUNK RELEASEYELLOW /GREEN ( + )DRIVER KICK PANEL HARNESS TO REAR
TACH SENSORBLUE/RED or BLUE  (AC)AT THE ECM/PCM *SEE NOTES*  2
BRAKEWHITE/ BLACK ( + )AT THE BRAKE PEDAL SWITCH
HORNGREEN/ YELLOW ( - )AT THE STEERING COLUMN
FACTORY DISARMWHITE   ( - )DRIVER DOOR MODULE IN DOOR
FACTORY ANTI-THEFTTYPETRANSPONDER
NOTES:
*1 - These wires will meter using the passenger door  lock switch.
*2 - The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the WHITE 31 pin connector E, pin 25.  On the 6 cylinder models it is in the GRAY connector A, pin 23.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
TrueSound
Posted: January 27, 2004 at 3:36 PM / IP Logged
Good looking out!!  Double Take
 If anyone has done one, and has some time savers please reply. . . . .
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
