Dome Supervision, Clifford Matrix RSX 3.5, 03 Dodge Dakota
diabloed
Copper - Posts: 133
Posted: February 05, 2004 at 2:27 AM / IP Logged
Ok I am working on installing a Clifford Matrix RSX 3.5 on a 2003 Dodge Dakota Extended Cab.
I have the door trigers all wired right, to the tan & tan/red. dioed isolated. But I am having troubles getting the dome supervision to work with it all. Should I have it with a diode off of one of the door trigers?
I have tried all sorts of combinations and have just confused myself!
Please Help
TIA
HamiltonAudio
Silver - Posts: 278
Posted: February 05, 2004 at 8:11 AM / IP Logged
I can't remember...are the door triggers negative or positive?  is there not a interior light under the dash area somewhere?  if so, can you not power the domelight supervision from that?  if not, you should be able to just trigger the doorpin....wire it "ahead" of the diodes and you should be ok.
b
diabloed
Copper - Posts: 133
Posted: February 05, 2004 at 8:16 AM / IP Logged
yeah they are negative, and there are no under dash lights. so i will try wiring ahead.
diabloed
Copper - Posts: 133
Posted: February 05, 2004 at 9:53 AM / IP Logged
Yeah not sure how i missed this one at 4am??? i had the door trigers double diode isolated from the BCM, and then had dome sup. wire heading into uncoming traffic..:)
HamiltonAudio
Silver - Posts: 278
Posted: February 05, 2004 at 2:18 PM / IP Logged
I figured that might be the case  Dome Supervision, Clifford Matrix RSX 3.5, 03 Dodge Dakota -- posted image.  So you were able to wire ahead of the diodes and get domelight supervision working just fine, right?  :)
b
