GM Keyless Bypass Module
gcar80
Member - Posts: 7
Posted: February 11, 2004 at 7:56 PM / IP Logged
Is it necessary to install a GM keyless entry bypass module to install a remote start/alarm system in a 2000 Chevy Z71? I have heard that there are ways around it but im not sure
magyver
Platinum - Posts: 12,488
Posted: February 11, 2004 at 8:47 PM / IP Logged
es, the Chevy has the Passlock II system on it.
tjdurham
Copper - Posts: 180
Posted: February 12, 2004 at 1:47 PM / IP Logged
you need a pldata and call it a day
tj
Big Dog
Gold - Posts: 1,265
Posted: February 12, 2004 at 2:08 PM / IP Logged
If I understood correctly you're asking about keyless entry. If so, then no you don't need any special module because doorlocks are done at the BCM.
Prepare your future. It wasn't the lack of stones that killed the stone age.
derek123
Copper - Posts: 163
Posted: February 12, 2004 at 2:24 PM / IP Logged
Locks are + trigger.
Does your aftermarket keyless have + outputs ?
if not you'll need relays and the + D.L. diagram found else where on this site.
gcar80
Member - Posts: 7
Posted: February 14, 2004 at 12:52 PM / IP Logged
What about the Passlock and anti theft system for the remote start because i know that if it is not done right the truck computer will think its getting stolen and will shut down the fuel system
magyver
kgerry
Platinum - Posts: 3,455
Posted: February 14, 2004 at 1:19 PM / IP Logged
yes you need to install a Passlock bypass module...almost every company makes one... we use the 555L from Directed...works great !!
whitey
Member - Posts: 49
Posted: February 14, 2004 at 1:21 PM / IP Logged
also note that if it has factory security witht he keyless entry system you will half to override it for remote start purposes.
Visions Edmonton
Installation Manager, DLS
MECP Certified First Class
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
