adding door lock actuators, help
95stangw
Member - Posts: 20
Posted: February 13, 2004 at 8:43 PM / IP Logged
Im adding door lock actuators to my 95 mustang with manual locks. I bought the actuators but they come with no instructions at all. I have no clue as to how to install them, does anyone have any diagrams on how they are mounted to the door?
As far as wiring should i wire the actuators to 2 relays such as is shown on the door lock section of this site? Or is there another way i can go about it?
all help is greatly appreciated.
daniel2002p
Silver - Posts: 524
Posted: February 13, 2004 at 9:25 PM / IP Logged
just find a goos spot where it wont interfere with other door components
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
95stangw
Member - Posts: 20
Posted: February 13, 2004 at 9:35 PM / IP Logged
I get what your saying, i looked at the parts and i see how they work. These are 2 wire actuators so i will wire them to 2 relays as shown on the door lock section on this site.
daniel2002p
Silver - Posts: 524
Posted: February 13, 2004 at 10:00 PM / IP Logged
you can do it like on the site, or I like to go out and purchase a DEI 451M, which is two realys already set up for a 2 wire actuator.  when you get it here is how to hook it up.  take the purple and put it to 12volts, take the WHITE/ black and BROWN / black and ground those two wires, and then finally take the GREEN/ black and blue/black to the two wires on the actuator.  cannot get simpler than that for about 20 bucks at any local retailer.  hope this helps.
    1.8L VVT-i I-4
95stangw
Member - Posts: 20
Posted: February 13, 2004 at 10:39 PM / IP Logged
Can i get the dei 451m anywhere online? if so please email it to me at :
caballerojaguar@earthlink.net
95stangw
Member - Posts: 20
Posted: February 25, 2004 at 9:09 AM / IP Logged
I just got the 451m in today, I noticed that on the plug that goes to the alarm there are 3 wires on it. ON the plug that came with the alarm there is only a green wire and a blue wire. The relay has a red wire that says +12 volt. Should i connect this wire to something? or does the alarm itself have a 12 output on that pin?
laren5
Copper - Posts: 57
Posted: February 25, 2004 at 11:36 AM / IP Logged
Just plug the white connector of the 451M into the alarm.   The alarm will take care of that red wire.
Greetings
Clifford Alarms
Sandungero24
Member - Posts: 44
Posted: February 25, 2004 at 5:56 PM / IP Logged
adding door lock actuators, help -- posted image.
Sandungero24
Member - Posts: 44
Posted: February 25, 2004 at 6:00 PM / IP Logged
this diagram only applies if the "trigger" wires from the alarm provide a pulsed ground (-) to lock/unlock. If they provide a pulsed positive (+) instead, you will have to ground the opposite 85/86 terminal to allow the relay to work. Actually, my alarm allowed me to use either pulsed (-) or (+), I just chose to use the (-).
95stangw
Member - Posts: 20
Posted: February 25, 2004 at 8:24 PM / IP Logged
thanks for the help, ill just go ahead and plug it into the alarm.
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
