Shock Sensor Fading
pcusick3
Member - Posts: 8
Posted: August 09, 2002 at 12:39 PM / IP Logged
I added a shock sensor to my factory alarm.  I piggy backed off the hood pin sensor.  The sensor it self is attached to the steering column under the dash.  After I installed it, it worked great, I adjusted the sensitivity and tested it multiple times.  Then, after I went for a drive, I tested it again.  It was much less sensitive.  I took the sensor off, and check everything and reinstalled it.  Again, It worked great.
So what I'm thinking is that the vibrations from driving are loosening the sensor.  I attached the sensor with two nylon zip ties.
Any suggestions on how else to install?  Thanks!
Platinum - Posts: 12,488
Posted: August 09, 2002 at 2:34 PM / IP Logged
Use sheet metal screws instead of zip ties to a flat spot on the under side of the dash.
