2004 F150 Driver Door Priority
Dolomite
Member - Posts: 12
Posted: February 18, 2004 at 11:11 AM / IP Logged
Has anybody wired up the driver door priority in a new 04 F150?  I've got the doors to lock and unlock using the main lock/unlock triggers which are negative ground but the wiring diagram for this vehicle shows that the driver door priority uses a 5 wire reverse polarity to unlock the drivers door and I can't figure out how to get this to work.
daniel2002p
Silver - Posts: 524
Posted: February 18, 2004 at 12:55 PM / IP Logged
your alarm has to be capable of doing that in the first place.  what kind of alarm is it?
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
bmf1000d
Silver - Posts: 345
Posted: February 18, 2004 at 1:27 PM / IP Logged
You would have to wire a rest at ground relays for the drivers door and then the other for the regular locks.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Dolomite
Member - Posts: 12
Posted: February 18, 2004 at 5:11 PM / IP Logged
Alarm is a Valet 554R.  This alarm has a programmable output for driver door priority.  The diagram I have only shows one wire for DD Priority but says it's a 5 wire reverse.
NowYaKnow
Gold - Posts: 1,217
Posted: February 18, 2004 at 5:55 PM / IP Logged
The wire for the driver door motor is RED / orange in the driver kick. Wire it up like so:
2004 F150 Driver Door Priority -- posted image.
Be sure to test everything. Offhand the motor side should be the side going towards the driver door and the switch side will be going towards the rear of the vehicle. Good luck,
Mike
Dolomite
Member - Posts: 12
Posted: February 19, 2004 at 12:02 AM / IP Logged
That worked.  Thanks for the help!!
Wednesday, November 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
