Remote Start on 2004 Scion
inazuma
Posted: February 20, 2004 at 3:33 PM / IP Logged
ok what the heck??  what are all those codes?? i cant edit it sorry.....Here i will try again..
I installed my alarm in my Scion xB and having trouble with the remote start..  I cant seem to find the starter wire. I know it has to be 12 volts on cranking, but I tested all wires in the ignition harness and cant find it.. the Scion color code list shows IGNITION (BLACK) and STARTER (BLACK)  there are 3 or 4 black wires and tested all of them.I am getting so frustrated..
Can you please tell me how to connect the starter?? What color is it or do I need to add a relay with a different wiring? I know how relays work..
I have installed remote starts in other of my cars with no problems, just the scion is giving me problems..
kgerry
Platinum - Posts: 3,455
Posted: February 20, 2004 at 4:42 PM / IP Logged
we dont have the Scion here but maybe its like the Ion's which dont have a starter wire, they energize start after acc shuts down
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
rudbwoy69camaro
Silver - Posts: 350
Posted: February 20, 2004 at 7:54 PM / IP Logged
MAKE : SCION, MODEL : XB, YEAR : 2004
12volts WHITE/ blue and WHITE/ red +ignition harness
Starter  black   +   ignition harness
Second Starter  N/A
Ignition  black   +   ignition harness
Second Ignition  BLACK / YELLOW   +   ignition harness
Third Ignition  N/A
Accessory  blue/red   +   ignition harness
Second Accessory  N/A
Keysense  yellow   -   ignition harness
Power Lock  blue/white   -   driver kick, 14 pin plug
Power Unlock  yellow/black   -   driver kick, 14 pin plug
Lock Motor  blue/orange   5wi  driver kick, 9 pin plug
Unlock Motor  YELLOW /GREEN   5wi  driver kick, 9 pin plug
Parking Lights+  green   +   headlight switch
Parking Lights-  N/A
Hazards  GREEN/ orange   -   hazard switch
Turn Signal(L)  GREEN/ black   +   top of fuse box, 13 pin plug
Turn Signal(R)  GREEN/ YELLOW   +   top of fuse box, 13 pin plug
Reverse Light  RED / black   +   top of fuse box, 9 pin plug
Door Trigger  RED / white   -   top of fuse box, 9 pin plug
Dome Supervision  use door trigger wire
Trunk/Hatch Pin  common with door trigger
Hood Pin  N/A
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  N/A
Factory Alarm Disarm  N/A
Disarm No Unlock  N/A
Tachometer  black   ac   data link connector, pin 9
Wait to start  N/A
Brake Wire  GREEN/ red   +   brake pedal switch
Parking Brake  black   -   parking brake switch
Horn Trigger  WHITE/ red   -   steering column
Probably going to have to do some testing.
inazuma
Posted: February 21, 2004 at 7:42 PM / IP Logged
Thanks..
i did some testing.  I also have the same color codes list.  My problem is: both black wires have 12 volts when i turn to ignition switch.  Neither has 12 volts only when cranking, which tells me which would be the starter..I tried cutting each individually and tried to start the car.  In both occasions, the car still cranks, but does not start.  WHich tells me the scion does not activate the starter as a conventional car.  there is probably some kind of special activation..maybe to ward off hot wiring???
Has anyone in this forum installed a remote starter on a scion?
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
