2004 Ford F-250 Superduty Install ?
tampa250
Member - Posts: 7
Posted: February 22, 2004 at 7:16 PM / IP Logged
First time poster here...
I have a 2004 Ford F-250 Superduty, and I recently had a local shop install a JT Plus security system.  It is an add-on to the factory keyless entry system, and uses my factory keyless entry remotes.  I have been back to this shop several times because the alarm is being triggered at least once a day, and I am at wit's end.
According to the LED flashes when I disarm it, the alarm is activating because of the current-sensing function.  the strange thing is that the DIP switch for current-sensing is turned off.  They switched out the alarm "brain" yesterday, thinking it was the culprit,  and the alarm activated again a few hours later.  This is causing me to leave the alarm in valet so that I do not aggravate the neighbors, which is totally defeating the purpose of the alarm.
I would appreciate it if anyone here has any tips about this vehicle.  I don't know why the alarm is going off for current-sensing when it is off.  The LED flashes once then pauses once disarmed, showing the current-sensing.  FYI, this vehicle also has the keypad on the driver's door for keyless entry.
Thanks in advance for your help!
Platinum - Posts: 12,488
Posted: February 22, 2004 at 9:02 PM / IP Logged
Chances are the GEM module is shutting down and the alarm thinks that the door was open and setting the alarm off. Does the shop that you had it installed at bypass the GEM for the door trigger's ??
brnichols03
Member - Posts: 21
Posted: February 22, 2004 at 10:02 PM / IP Logged
or diode isolate them
firedog
Posted: February 23, 2004 at 6:26 AM / IP Logged
I think both Velocity Motors and brnichols03 have it right.
I had the same problem with my 1999 Superduty Powerstroke.  After about 20 minutes, the alarm would trigger for no apparent reason.  I installed the Valet 554R (awesome. . .).  I have access to the factory service CDs, and found my answer:
I wired both door sensors together and tied them to the door trigger input (-) for the CPU.  I placed a diode on each lead going to the sensors, so they stay independent of each other.  What I did not do was place a diode in the line from the sensor to the GEM.  What happens is the GEM "goes to sleep" to conserve power, and when it does the sensor wires "float", and the CPU interprets that as a trigger to set off the alarm.
The solution is to wire in a diode in line with each sensor wire, with the stripe pointing to the door.  Then, do the same thing on the leads going to the CPU.  This will isolate both sensors from each other, and isolate the GEM from the CPU.
I don't have the time right now to sketch out a diagam, but I will when I get home from work and post it in here.  BTW, I had the same situation on a '04 Ranger, with the same solution.  Sorry if the description is hard to understand, but it will be simple once you see it in a diagram.
PM me or email me ( bruce@jnbsystems.com) if you have any questions.
Thanks,
Bruce
tampa250
Member - Posts: 7
Posted: February 23, 2004 at 7:52 AM / IP Logged
Thanks for the replies.  I will forward this info to my installation shop.
Please forgive my ignorance on the subject, but what is the "GEM"?  And, why is the alarm showing one flash on the LED when disarmed which means a current-sensing alarm activation?  Remember, the #5 DIP switch is turned off which should be disabling the current-sensing.  Again, this is a JT Plus system if that helps at all.
Maybe if any of you could cite the exact wires in the vehicle that need to be accessed it would be helpful.  From what you all are telling me, it sounds like maybe the install shop used the wrong door wires in the truck.  Everything else works fine- the locks work properly and still self-lock when driving off as when factory, my keypad on the driver's door works properly, etc.
Thanks again for all of the advice!
cfurtick
Member - Posts: 7
Posted: February 23, 2004 at 5:08 PM / IP Logged
DEI gave me some info one time on turning off gem sleep mode.... It should work as well
Ignition on
unlock 3 times
Ignition off
unlock 3 times
Ignition on
unlock 2 times
hope this helps
tampa250
Member - Posts: 7
Posted: February 23, 2004 at 5:55 PM / IP Logged
Any drawback to disabling the "sleep mode"?  And cfurtick, is that the unlock and lock buttons on the remote or the switch in the vehicle?
Thanks for trying to help...
mobile1
Silver - Posts: 479
Posted: February 23, 2004 at 10:54 PM / IP Logged
the GEM disarms works perfect no drawbacks. we've been doing that at my shop for a while and had no issues. Just a heads up you have to have the doors close when doing this.
tampa250
Member - Posts: 7
Posted: February 24, 2004 at 1:47 PM / IP Logged
So, do I use the lock and unlock buttons on the remote or the main switch in the vehicle?
UPDATE:  On Sunday, I unplugged the alarm "brain" and plugged it back in.  I also turned the #5 DIP for current-sensing 'on' and 'off' once.  I did this out of sheer desperation, and have been checking the vehicle.  The alarm has not been triggered for current sensing yet.  I'll check it again tonight when I get home and see if it is still untriggered.
How long does it take for this GEM issue to cause a false trigger?  In other words, if my problem is the GEM would it take two days to cause the alarm to go off or would it already have done it since Sunday when I unplugged and reconnected the "brain"?  Just trying to troubleshoot this down as far as possible.  I would LOVE to not have to drop the truck off at the shop again this Saturday.
I appreciate everyone's help.
SSteve
Member - Posts: 20
Posted: February 24, 2004 at 7:01 PM / IP Logged
Stop messing up your beautifull new truck,
do you really need an alarm?
Steve
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
