remote start in 92 Voyager
videoviking
Member - Posts: 15
Posted: February 22, 2004 at 9:05 PM / IP Logged
Starter cranks, but engine doesn't catch.  The brain has two extra Ignition "On" wires.  The manual says one is to be used if a second ignition on is needed, and the other is to be used for AC.  The question is, does the Voyager need the second ignition, and if so, what wire is it?  and the next one is where is the tach wire
Chuck Johnston
Bnluis
Silver - Posts: 578
Posted: February 22, 2004 at 9:10 PM / IP Logged
        12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness
    TACHOMETER|gray,RED / yel,blu/yel|   |coil pack *1
Notes:
*1 The 3.3, 3.5, and 3.8L V6 engines use a triple coil pack. Wire colors are for 2 cylinders each. The gray wire may also be gray/black
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
videoviking
Member - Posts: 15
Posted: February 22, 2004 at 11:04 PM / IP Logged
BNLuis,
Okay, my next question is where is the coil pack  There is a row of relays on the drivers fenderwell, and then I have one wire from the brain that says to attach to the oil pressure switch or to wrap around the coil wire.  Or, should I just make three leads and attach them to the coil wires and then into the tach sensor on the alarm?
Chuck Johnston
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
