2002 Cavalier Passlock II Help
timsshadow
Member - Posts: 9
Posted: February 28, 2004 at 9:38 PM / IP Logged
Can anyone help me in the steps required to install a 555 bypass module for a 2002 Cavalier.  I have basic knowledge of installs (more car audio than security) but I would appreciate any help anyone can give me.  the instructions are not a lot of help.  I do have a RS that does work, but the anti-theft kicks in and shuts the car down.  Please be as specific as possible if you can.  I found the Yellow resistance wire (that one I know is right) but I am having difficulty finding the right black wire....
To Get Someone's Attention, You Can't Merely Tap Them On The Shoulder, You Have To Hit Them With A Sledgehammer.
daniel2002p
Silver - Posts: 524
Posted: February 28, 2004 at 10:21 PM / IP Logged
ok lets see,
cut the yellow wire in half and hook up the yellow wire form the bypass unit to the ignition side of the cars passlock wire and the BLACK / YELLOW to the ground side of the cars passlock wire.  the black wire goes to the BLACK/ orange that is under the dash, just tap it in, do not cut this one, and finally, the pink wire goes to ignition.  that should do it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
daniel2002p
Silver - Posts: 524
one more thing.  take the lack wire and hook it up to the third ignition in your alarm, and the red to constant 12v.
    1.8L VVT-i I-4
