Autopage 850lcd, 92 Bonneville
jeffbayne
Member - Posts: 6
Posted: March 08, 2004 at 11:33 PM / IP Logged
Hey guys, this coming weekend i'll be putting an 850 in my bonneville.  I have the VATS chip in my key, and have a Designtech module for that.  I've gotten the wire diagrams off of here.  Anything special I need to know???  Any heads up about this alarm, or the car?
Thanks guys!
jeff
ECD 416~*~5061~*~Kimber Select~*~DAC 348~*~PA2~*~XM3~*~202m~*~160-03kx~*~NX-30~*~DDC-R17F~*~ZR600~*~88120dvc~*~Zeronoise~*~Yellowtop
Platinum - Posts: 12,488
Posted: March 08, 2004 at 11:46 PM / IP Logged
Is this for the SSE or SSEI  or a lower model ?
JakeJ
Member - Posts: 38
Posted: March 08, 2004 at 11:48 PM / IP Logged
    I am not familiar with the alarm but the vats bypass should be a snap.   Good luck this weekend!
Wyoming 12volt Enthusiast
jeffbayne
Member - Posts: 6
Posted: March 09, 2004 at 1:29 AM / IP Logged
base model SE.  not supercharged.
Posted: March 09, 2004 at 8:41 AM / IP Logged
(+) Type door lock system : If your system does not have alternating polarity door locks, then you need relays to convert the signal of the (-) to a (+), use this diagram.
OEM Alarm Disarm : Wire is located in the dirver's kick panel and is light green in color. Will test (-) when unlocked.
Tachomeetr Wire : This wire is PURPLE / WHITE and is located at the ignition module or a WHITE wire the instrument cluster on models with a tachometer
VATS bypass: You can either buy a module to install which will autodetect the resistor value and save you time or you can measure the chip in the key and use this diagram for a home built module.
