1995 Mercury Trunk Release
Trav3D1
Copper - Posts: 146
Posted: March 12, 2004 at 9:15 PM / IP Logged
I recently installed a Prestige Platinum APS-996 on a 1995 Mercury Grand Marquis.  Everything is working just fine, but the trunk release.  I have wired up a relay using the following configuration:
87(a) - switch side of the trunk release, 30 - actuator side of the trunk release, 85 - 12 volts, 87 - 12 volts, and     86 - to (-) pulse output of alarm module
The trunk is not working at all.  Does this configuration make since, or am I still doing something wrong.
Thanks in advance
Trav
Trav3D1
Copper - Posts: 146
Posted: March 13, 2004 at 6:32 AM / IP Logged
Any suggestions
Trav
draasch
Gold - Posts: 2,172
Posted: March 13, 2004 at 2:44 PM / IP Logged
Trunk Release PURPLE / YELLOW (+) HIGH IN DR. KICK PAN ON CON BRACKET * #232
http://www.wiringinstructions.com/232.htm
86-87 12v
85 - output from alarm
30 solenoid
87a switch side
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
