Viper owner & Pros.Please help
cargovan
Member - Posts: 14
Posted: March 13, 2004 at 3:02 AM / IP Logged
when the eng .turn off ,the 2 front do not unlock automatticly but the back &sliding side do
when start the eng. all door lock
it's a 04 chevy express.the alarm is viper 791.
the  alarm was set up as follow;
    LOCK       button on the remote ( lock all dood)
    UNLOCK ...................................     ( unlock rear & sliding )
     AUX .................................................(press for more than 1 sec. 2 front open)
      LOCK & UNLOCK ...................     (  AT the same time .remote start )
kgerry
Platinum - Posts: 3,455
Posted: March 13, 2004 at 10:55 AM / IP Logged
well unless you changed the factory configuaration pressing lock and unlock together is activating timer mode, not RS.  RS is activated by pressing the snowflake button ( * ) two times.....
also, AUX is a delayed validity channel and you have to hold it for about 4 secs. to activate this channel.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Teamrf
Gold - Posts: 1,031
Posted: March 13, 2004 at 11:08 AM / IP Logged
Make sure you have the engine controlled door locks on in the alarm settings.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
