No alarm at entry of vehicle
seanster
Member - Posts: 8
Posted: March 17, 2004 at 3:06 PM / IP Logged
OK I just installed my rattler 310D in a 97 4 door Explorer. I tested the alarm for the first time. I can turn it on, it locks my doors fine, shock sensor works fine 2 BUT, I can use my key to unlock the door, open it and no alrm goes off !! Untill the shock sensor feels the door close or if i get in too hard!
What did I do wrong?
pink / YELLOW + lock
pink/green - unlock
draasch
Gold - Posts: 2,172
Posted: March 17, 2004 at 3:11 PM / IP Logged
sounds like you didnt hook up the door trigger...
blk/LT blue + door trigger
Make:   Ford
Model: Explorer
Year:    1997
Alarm
Constant 12 volts YELLOW (2) IGNITION SWITCH HARNESS
Ignition 12 volts L GREEN/ PURPLE IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) AT COURTESY LIGHT *
Trunk Pin Switch SAME AS ABOVE
Parking Lamp WHITE/ BLACK (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVER KICK #201
Power Unlock PINK/L GREEN PANEL
* BLACK/ L BLUE (+) Wire Also Located At Interior Lamp Switch. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: March 17, 2004 at 4:31 PM / IP Logged
Also your unlock wire polarity needs to be the same as your lock polarity. For the Ford it's a (-) for both lock and unlock.
seanster
Member - Posts: 8
Posted: March 19, 2004 at 8:36 AM / IP Logged
 Alright got it thanks everybody.
seanster
Member - Posts: 8
Posted: March 19, 2004 at 10:11 AM / IP Logged
Wait...I didnt get it..false alarm it was shock sensor that set it off. The balck/light blue wires (2) are both negative even when ddor is open.
And another thing. Does anyone know what color the parking light is at the kick panel?
seanster
Member - Posts: 8
Posted: March 19, 2004 at 1:03 PM / IP Logged
Got IT for sure this time! The BLACK/ light blue were 3 wires connected with a diode.
And the parking lights were PURPLE / white.
auex
Platinum - Posts: 5,041
Posted: March 19, 2004 at 10:55 PM / IP Logged
Don't connect all of the BLACK/ lt.blue together with diodes, they are not all door triggers (if this is what you meant). There should be a couple that will test, but you only need to tie into ONE of them.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
