rsx 3.5 questions
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 3:30 PM / IP Logged
I just had my clifford rsx 3.5 installed yesterday...in my 2002 denali....we came across two ignition wires for the remote start when started the pink wirk has no volts......we just capped it and did not connect it to anything..the car starts but we are haveing problems.. the lcd when unlocked will read that it has been triggered.. and the led lights stays blinking twice...and i cant program the other remote...can this have something to do with that pink heavy gauge wire diconected......any help appricated......thanx
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 3:39 PM / IP Logged
please any help
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 3:59 PM / IP Logged
ttt
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 4:45 PM / IP Logged
any one can help?
draasch
Gold - Posts: 2,172
Posted: March 18, 2004 at 4:53 PM / IP Logged
here is what i have...double check the wires...
Make:   GMC
Model: Yukon
Year:    2002
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light PURPLE LIGHT SWITCH HARNESS
Trunk Pin Switch
Parking Lamp BROWN (+) LT. BLUE PLUG AT BCM *
Power Lock L BLUE ON BCM AT BASE OF #202
Power Unlock WHITE STEERING COLUMN
#202 - See Positive Pulse Door Lock Diagram. * BCM Is Located Behind The Driver's Side Dash.
Remote Start
Tach Signal WHITE AT ECM * #238
Ignition #2 WHITE IGNITION SWITCH HARNESS
Ignition #3 ORANGE IGNITION SWITCH HARNESS
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) DRIVER'S DOOR SILL HARNESS
Rear Window Defrost N/A
#238 - See G.M. Passlock II Diagram. * ECM Is Located Near The Battery Under Black Cover.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 5:18 PM / IP Logged
We did not use the pink heavy gauge wire on the harness because ....we already had an ignition wire....could this wire not being connected giving me problems
Duke70301
Member - Posts: 19
Posted: March 18, 2004 at 5:44 PM / IP Logged
Any one know the clifford are viper 791 alarms?
rudbwoy69camaro
Silver - Posts: 350
Posted: March 18, 2004 at 6:04 PM / IP Logged
Who installed it? Take it back I say.
Toru
Copper - Posts: 102
Posted: March 18, 2004 at 6:48 PM / IP Logged
Ok, the 2002 Denali has this:
Ignition #1: PINK (# AWG) IGNITION SWITCH HARNESS
Ignition #2: WHITE (# AWG) IGNITION SWITCH HARNESS(ECM)
And the Matrix RS3.5 has two ignition outputs (pink and pink/white).
Why wouldn't you connect both?
JWorm
Platinum - Posts: 2,208
Posted: March 18, 2004 at 7:47 PM / IP Logged
Pink -> pink in car
Pink/white -> white in car
Problem solved
If the pink ignition wire on the 3.5 doesn't see ignition you won't get into programming, your starter kill won't work, you can't learn tach, you can't put it into valet using the valet button, and more. Hook it up.
