94 Honda Passport car security
prieur
Posted: March 23, 2004 at 9:38 AM / IP Logged
Can anyone email me the wiring schematics for a 94 Honda Passport in order to install a remote starter and car alarm.
thanks
Big Dog
Gold - Posts: 1,265
Posted: March 23, 2004 at 9:41 AM / IP Logged
Try this:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|black               |+ |ignition harness            |
|          STARTER|wht/blu or blk/wht |+ |ignition harness            |
|   SECOND STARTER|blk/red or green    |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
|        ACCESSORY|blue               |+ |ignition harness            |
|       POWER LOCK|add actuator        |   |in drivers door             |
|     POWER UNLOCK|                    |   |                            |
| PARKING LIGHTS +|GREEN/ red           |   |by left front speaker       |
|       HEADLIGHTS|RED / blue            |- |at light switch             |
|     DOOR TRIGGER|RED / green           |- |2 pin plug by LF spkr.      |
| TRUNK/HATCH PIN|lt. green           |- |drivers kick or *2          |
|TRNK/HTCH RELEASE|RED / blue            |+ |at switch                   |
|       TACHOMETER|blue, BLACK/ red     |   |at coil, coil pack          |
|       BRAKE WIRE|red                 |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN/ red *3        |- |steering column             |
|           WIPERS|blue               |+ |at switch                   |
| LF WINDOW UP/DN|RED / yel - grn/yel   |A |drivers door switch        |
| RF WINDOW UP/DN|blu/wht - blu/blk *1|A |drivers door switch        |
| LR WINDOW UP/DN|RED / blu - grn/blu *1|A |drivers door switch        |
| RR WINDOW UP/DN|RED / blk - grn/blk *1|A |drivers door switch        |
Notes:
*1 The window wires change color in the drivers kick. The R.F. window is grn/red for up and RED / yel for down. The L.R. window is grn/orn for up and RED / blk for down. The R.R. window is grn/blu for up and red for down.      *2 behind left rear side panel at the rear wiper diode.    *3 High-current ground. Use a relay when interfacing with this circuit.
Saturday, July 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
