Prelude 89 Alarm Installation Remote Strt
Tengoku
Member - Posts: 6
Posted: March 29, 2004 at 3:20 AM / IP Logged
Ive searched and looked at all the posts pertaining to this topic and read them all, hoping it will help me complete the wiring that i need for my alarm.. I also surfed https://www.the12volt.com
Ive scanned these diagrams! can you guys help me link what I need to connect?! you guys are soo cool!  :roll:
I need to know what color I should connect in this blue diagram..
heres what I got so far (sorry for the big pics)
Prelude 89 Alarm Installation Remote Strt -- posted image.
heres the whole wiring diagram for the car
Prelude 89 Alarm Installation Remote Strt -- posted image.Prelude 89 Alarm Installation Remote Strt -- posted image.
and heres what I need to connect
thanx in advance
draasch
Gold - Posts: 2,172
Posted: March 29, 2004 at 5:57 AM / IP Logged
Make:   Honda
Model: Prelude
Year:    1988-91
Alarm
Constant 12 volts WHITE/ BLACK AND WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) WHITE CONNECTOR RIGHT OF COLUMN
Trunk Pin Switch GREEN/ BLACK (-) TRUNK LIGHT OR DRIVER KICK PANEL
Parking Lamp RED / BLACK (+) AT LIGHT SWITCH OR FUSE BOX
Power Lock GREEN / WHITE DRIVER KICK PANEL #201
Power Unlock GREEN/ RED DRIVER KICK PANEL #201
#201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal BLUE AT COIL
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 BLUE/WHITE IGNITION SWITCH HARNESS
Accessory WHITE/ RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN/ BLACK (+) AT SWITCH BELOW CONSOLE
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Tengoku
Member - Posts: 6
Posted: March 30, 2004 at 1:43 AM / IP Logged
can someone help me locat the trunk pin.. i looked in the kick panel, and I see a hole bunch of relays with wires connected to them all with the same color as the trunk pin (green black).. which one is it????
lewdlude
Member - Posts: 10
Posted: April 28, 2004 at 8:10 AM / IP Logged
Take a volt meter and test the wires with the trunk open. Then close the trunk and check all the ones that had power with it open. The one that changes with the trunk is the correct wire.
89 Prelude Si2.0
-JVC deck, Alpine 6.5's, Lanzar amp for Lanzar 6x9's, Xplod amp for 2 Xplod 10s
"Drive fast and don't take any of this stuff seriously." - Some kid from Space Camp
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
