1997 Merc. Mountaineer Alarm
Dragorus
Copper - Posts: 75
Posted: April 01, 2004 at 3:18 PM / IP Logged
I am having a problem with the factory disarm wire....When I lock my vehicle with the new alarm I have it to pulse neg to the fact. disarm wire....But when I lock it the domelights do not shut off.....What I am noticing is the factory alarm is also sending a neg signal down the disarm wire to arm the fact system....So should I send a neg pulse with the lock function of my aftermarket alarm?....Anyone got a DEI Wiresheet or can give me info on the factory disarm and domelights / door triggers?
jfk51502003
Copper - Posts: 221
Posted: April 01, 2004 at 3:33 PM / IP Logged
12volts yellow   +  ignition harness
Starter RED / lt. blue   +  ignition harness
Second Starter
Ignition GREEN/ purple   +  ignition harness
Notes: Two wires each at switch, both are common, only need to power 1 each during remote start.
Second Ignition
Third Ignition
Accessory gray / YELLOW   +  ignition harness
Second Accessory BLACK/ green   +  ignition harness
Keysense
Power Lock pink / YELLOW   -  driver kick panel
Power Unlock pink/green   -  driver kick panel
Lock Motor pink/black    driver kick panel
Unlock Motor RED / orange    driver kick panel
Parking Lights+ PURPLE / white    driver kick panel
Notes: Also found to be WHITE/ black at the rear of the switch.
Parking Lights- WHITE/ purple    driver kick panel
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ lt. blue   +  driver kick panel
Notes: To avoid the dome light delay and dome light time-out use the separate door triggers. In the drivers kick panel find yellow/black for the drivers door, lt. GREEN/ YELLOW for the drivers rear door, and WHITE/ purple for the rear hatch. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All five wires are negative trigger and must be diode isolated together.
Dome Supervision BLACK/ lt.blue   +  driver kick panel
Trunk/Hatch Pin common with doors
Hood Pin tan/lt.green   -  driver kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms on lock
Notes: Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.
Factory Alarm Disarm dk. GREEN/ purple   -  driver kick panel
Disarm No Unlock
Tachometer tan / YELLOW  AC  PCM
Notes: The PCM is located at the top of the firewall towards the passenger side, the tan / YELLOW tach wire is also found at the back of the instrument cluster.
Wait to start
Brake Wire lt.green   +  driver kick panel
Parking Brake
Horn Trigger yellow/lt. green   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
1997 Merc. Mountaineer Alarm -- posted image.
Immobilizer Bypass Module:Required: YesType: PATSPart #: 555F or 555U
Notes: N/A
Dragorus
Copper - Posts: 75
Posted: April 01, 2004 at 3:42 PM / IP Logged
Is that for the 97 ?
jfk51502003
Copper - Posts: 221
Posted: April 01, 2004 at 4:47 PM / IP Logged
yup...hope it helps...!!!
Dragorus
Copper - Posts: 75
Posted: April 01, 2004 at 5:12 PM / IP Logged
Thanx a bunch!
