Peterbuilt, Kenworth and such
draasch
Gold - Posts: 2,172
Posted: April 08, 2004 at 3:32 PM / IP Logged
I am looking for some wiring info the these types of trucks. I have a company that wants me to install GPS tracking systems in some big rigs. they all have power locks. i will need the main wiring info as if i was installing an alarm. this units will only unlock the doors. the other issue is the unit have a wire to disable the starter. now the relay can be triggered from a phone call to the unit. not all truck have a starter wire. some use air to start. so i may have to use a fuel shut off type system. if anyone has some info that may help, please feel free to send it to me @
acesecurity@12voltsecurity.com
or
fireman481@verizon.net
thanks for the input..
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jfk51502003
Copper - Posts: 221
Posted: April 08, 2004 at 5:37 PM / IP Logged
12volts
Startertan  ignition harness
Second Starter
IgnitionRED / black  ignition harness
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+brown  at headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggertan / YELLOW - at light switch
Dome Supervision
Trunk/Hatch Pintan  at pin switch
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Peterbuilt, Kenworth and such -- posted image.
Platinum - Posts: 12,488
Posted: April 08, 2004 at 5:49 PM / IP Logged
You will need to use a DMM on the wires for this truck. Becareful though because some systems on the truck are 24 volts.
draasch
Gold - Posts: 2,172
Posted: April 08, 2004 at 6:50 PM / IP Logged
thanks for the info guys...
Good Luck
David
Ace Security
813-376-9778
Tampa
jimmeezgolfvr6
Silver - Posts: 258
Posted: April 08, 2004 at 7:07 PM / IP Logged
one really annoying thing is that these trucks sometimes use wiring that's all the same colour! as am example, the entire bunch of wires leading to the ignition cylinder may be yellow, all wires related to lighting or illumination could be tan, etc.
good luck!
auex
Platinum - Posts: 5,041
Posted: April 08, 2004 at 8:19 PM / IP Logged
Yes most of the wires are the same color, but they are numbered. Do the first one using the meter then write the wire number down, be careful there is a wire number and the length number. If the truck is a Mack then open the glove box and there are posts that you can use ring terminals on to tie into power, ign, ground, etc...
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jimustanguitar
Member - Posts: 16
Posted: April 09, 2004 at 3:34 AM / IP Logged
if you know which bundle a wire is in, but not which one it is... you can use a signal injector and tracer. if you can find one end of the wire that you want to locate somewhere in the middle of its run, you can "inject" a signal and then find it with the tracer (kind of acts like a stud finder over the wire with the injected signal). partsexpress.com sells them, you may find one useful. good luck
draasch
Gold - Posts: 2,172
Posted: April 10, 2004 at 12:43 AM / IP Logged
thanks for all the input guys!
Good Luck
David
Ace Security
813-376-9778
Tampa
