alarm/door lock trigger
pat miller
Posted: August 23, 2002 at 2:04 PM / IP Logged
I have a Crimeguard CS9900 alarm installed and would like to also install an aftermarket power door lock system and operate with the alarm remote. This alarm does not have a door lock output trigger, but does have a starter disable relay output that is open when disarmed and grounded when armed. Any suggestions on how to convert this to a - or + pulse to use for a door lock trigger?
Thanks for your help.
oldboy
Member - Posts: 24
Posted: August 25, 2002 at 6:20 AM / IP Logged
Pat, DEI do sell a module called a 452T module which is a pulse generator. It uses the ground when armed output and converts it to either a positive or a negative trigger. If you intend to run a solenoid off this, you would then also need to use a pair of relays or a DEI 451M module. Good Luck
pat miller
Posted: August 26, 2002 at 1:39 PM / IP Logged
This is exactly what I need. I just ordered one.
Thanks for the help,
--pat
