Starter Kill Problem
skizot722
Posted: April 19, 2004 at 1:58 PM / IP Logged
I'm having problems installing a starter kill on a 1972 camaro. the column has two purple wires coming out of it, one is just purple and the other is purple and white. i cut the purple and white wire and then tried to start the car. won't crank. so i thought i had the right wire and installed the starter kill relay using that wire. now i can't start the car with the relay installed. any ideas?
thanks in advance
skizot722
Posted: April 19, 2004 at 2:00 PM / IP Logged
err... it's a chevelle
draasch
Gold - Posts: 2,172
Posted: April 19, 2004 at 2:30 PM / IP Logged
how do you have it wired up??????
did u make sure you are using the starter wire???
find the starter wire and cut in two:
86 12 volts
85 ground when armed
30 to key side of starter wire
87a to remaining wire for starter....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
