RS Antenna from Prestige to DEI
Dteg
Member - Posts: 6
Posted: April 24, 2004 at 8:25 PM / IP Logged
I installed an Audiovox 966a and it works but the range is dissapointing. I was wondering if I it would help any if I switched to the DEI antenna, they both use 4 pins on thier plugs, DEI  is about 3 times longer that that stubby one that comes with the Prestige 966a. Let me know if it possible.
AutoObsessions
Member - Posts: 26
Posted: April 26, 2004 at 12:51 AM / IP Logged
I am not sure if you are even able to use a dei antenna with this system. There might be a problem with your system or just a bad antenna even though I have never encountered a problem with these. The last one of these that I installed I was able to start the car from 5 blocks away.
Dteg
Member - Posts: 6
Posted: April 27, 2004 at 5:13 PM / IP Logged
 I really don't think the alarm is defective I just think the range sucks.  I forgot where I read the range on the APS 966a is only about 1000'.  If I had a 5 block range I would be very happy.  I'll live with it for now but I will upgrade when I find a good deal on a better unit  in the future.
jfk51502003
Copper - Posts: 221
Posted: April 27, 2004 at 5:41 PM / IP Logged
WHERE IS ANTENNA MOUNTED...?
Dteg
Member - Posts: 6
Posted: April 27, 2004 at 5:44 PM / IP Logged
On the windshield upper center area
godsegoizhuge
Copper - Posts: 214
Posted: April 27, 2004 at 8:32 PM / IP Logged
try moving the antenna. sometimes that helps, esp if the car has some sort of factory tint at the top.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
