starter interrupt
davidwp13
Member - Posts: 28
Posted: April 29, 2004 at 6:33 PM / IP Logged
 Hi I have a Python 660XP and have the AED ( interrupt ) hooked to the right wire, I think when I unplug the relay it will not atart,BUT how do I know if it is working properly?
 I did ENABLE it by using the valet and the remote to get 1 BEEP.
 ANY HELP??
David
draasch
Gold - Posts: 2,172
Posted: April 30, 2004 at 3:22 PM / IP Logged
i dont use that brand, however i would think you can set the alarm and then trigger it and while the alarm is sounding, see if you can start the car.......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
kgerry
Platinum - Posts: 3,455
Posted: April 30, 2004 at 3:43 PM / IP Logged
ROLL DOWN THE DRIVERS WINDOW, ARM THE ALARM AND REACH THRU AND TRY TO START IT WITH THE KEY.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
