2000 nissan xterra prestige aps785
827c
Posted: May 01, 2004 at 8:23 PM / IP Logged
I got a prestige alarm model aps-785. The local shop installed it and anytime you remote start it with the doors locked the factory alarm goes off.  At first they said they couldnt do anything so I never went back and 6 months later I show up complaining about their install. They try to redo it and still cant get it right, they have had it 3 times. It was put into a 2000 nissan xterra. They claim that none of the wires their diagram mentions is the factory disable wire. To me it seems like something is wrong with their alarm. I searched on here and found a little bit. Do you think the alarm isnt sending a signal to the locks to disable it. What do you guys think thanks for any help
Autoobsession
Copper - Posts: 119
Posted: May 01, 2004 at 8:48 PM / IP Logged
OK well this install shop sounds like they suck lol. On all audiovox remote start systems there should be a 4 pin plug. Two of the wires on this plug are BLACK / YELLOW and BLACK/ blue. All of these four wires are set to send out a negative pulse at different times. The BLACK/ blue sends one out right b4 the remote starter starts and the BLACK / YELLOW sends one out after it has started.
Since this cars factory alarm and disarm wires are the same as the keyless entry lock and unlock wires those two wires must be used. The BLACK/ blue must be wired in with the unlock wire and the BLACK / YELLOW with the lock wire. What this does is when you remote start the car the car will unlock briefly to turn off the factory alarm and then will relock once it is started. This will fix your problem definitly. Hope this helps.
Platinum - Posts: 12,488
Posted: May 02, 2004 at 9:32 AM / IP Logged
A single pulse to the unlock wire will disarm the factory alarm without unlocking the doors. So just use the wire that Autoobsession suggested to pulse once before remote start and your good to go.
827c
Posted: May 02, 2004 at 10:37 AM / IP Logged
Should I do this myself or take it back t the shop and tell them how to do it. On my other cars i bought an alarm and had it installed it worked fine. Ive never worked on an alarm how hard would is it? Thanks for all your help. My friends shop  had it apart and said we needed a plug, the plug you guys are talking about is it seperate or with the main harness Thanks for your help it isd greatly appreciated and I cant wait to get this fixed
Autoobsession
Copper - Posts: 119
Posted: May 02, 2004 at 10:44 AM / IP Logged
They might have not installed the plug so I would take it back there and have them do it. If they dont have one they have to get one for you since they didnt use it. If they sell audiovox that shouldnt be a problem.
827c
Posted: May 03, 2004 at 2:04 PM / IP Logged
okay I have an appointment on Wednesday. Are all of the plugs the same or are they different with different models? Hopefully they have the same model in stock. Again thanks for your replys
Autoobsession
Copper - Posts: 119
Posted: May 03, 2004 at 10:03 PM / IP Logged
All of the recent Audiovox remote starters have this 4 pin plug. Since they are not needed on every install I am sure they have them in stock.
827c
Posted: May 06, 2004 at 3:45 PM / IP Logged
Its finally done. They said it was more complicated than just the plug, but they said it didnt take that long and we came back after half an hour and they werent done. Finally done after 10 months. thanks for the help
