98 chevy p/u by passing vats
69nitrobrian
Member - Posts: 7
Posted: May 09, 2004 at 6:23 PM / IP Logged
 I have 98 chevy p/u that has a factory theft system. Is this the vats system that  has to be  by passed for the remote start to work?   I'm installing an Autopage 850. How do I by pass it? Thanks alot Brian.
rudbwoy69camaro
Silver - Posts: 350
Posted: May 09, 2004 at 6:56 PM / IP Logged
Passlock II imobilizer.  There are alot of transponder bypass choices out there.  Pick one...
I found one on ebay for $.01 , geez-a penny to start !
http:///.com/ebaymotors/dll?ViewItem&rd=1&item=2477915183&category=33724&sspagename=WDVW
1998 Chevrolet Full Size Pickup
ItemWire ColorPolarityWire Location
12Vred+ignition harness
STARTERyellow or purple+ignition harness
IGNITIONpink+ignition harness
ACCESSORYorange+ignition harness
SECOND ACCESSORYwhite *5+ignition harness
TACHOMETERwhite *3ECM *4
POWER LOCKlt. blue*2either door boot
POWER UNLOCKwhite*2either door boot
PARKING LIGHTS +brownswitch or fuse panel
PARKING LIGHTS -none
DOOR TRIGGERpurple or ppl/wht-light switch
HEADLIGHTSyellow+at switch
WIPERSpurple+steering column
LF WINDOW UP/DNdk. blue - brownAat drivers door switch
RF WINDOW UP/DNlight blue - tanAdrivers door or boot
LR WINDOW UP/DNgreen - purpleAdrivers door or boot
RR WINDOW UP/DNlt. grn - pur/whtAdrivers door or boot
TRUNK/HATCH PINnone
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERblack-at column
BRAKE WIREwhite+at brake pedal switch
LOCK MOTORgraydrivers kick panel
UNLOCK MOTORtandrivers kick panel
DISARM DEFEATtanpassengers kick panel
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The pink/white does not exist on all models. *2 5 wire (type C) on the two door models, and positive trigger (type A) on the four door and keyless entry models. *3 Tach wire on the 6.5 Diesel is white at the instrument cluster. Diesel wait to start wire is dk. blue (-) located at the instrument cluster 'see directfax document #1090'. *4 ECM located on drivers side inner fender well. Two plugs, white wire in plug marked 'white'. *5 Make sure to enable second ignition wires for remote starts to prevent possible transmission damage and the check engine light from coming on.
CutDog504
Silver - Posts: 643
Posted: May 10, 2004 at 2:01 AM / IP Logged
The absolute easiest way to bypass passlock by far is by using a PLDATA databus bypass module. All you do is connect a hot, a ground, a trigger wire from the remote start, and one wire to the purple databus wire in the truck. Plus I like the fact that you don't have to tear the column apart, all connections are under the dash when you use a PLDATA. Look at www.bypasskit.com
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
