05 caravan knee cluster airbag
desh187
Copper - Posts: 310
Posted: May 17, 2004 at 9:58 PM / IP Logged
Has anyone installed an alarm on 2005 dodge caravans?
Wiring schematic is the same as 04 except the standard knee cluster air bag.It is a little difficult to get to the ignition harness as the inner driver dash plate cannot be removed(air bag).
Has anyone found an easier way around ?
deviousjoker
Copper - Posts: 102
Posted: May 18, 2004 at 4:42 PM / IP Logged
that sucks
First Class MECP Installer
mxxmikexx
Silver - Posts: 796
Posted: May 18, 2004 at 5:45 PM / IP Logged
do any other cars for 05 have knee airbags? if more car makers start installing knee bolster airbags our jobs of tagging wires for alarms/remote starters is going to be a pain in the ass.
johnmax
Copper - Posts: 131
Posted: May 18, 2004 at 8:23 PM / IP Logged
The Lexus RX 330 does. You can unbolt it and lay it on the floor though (without unplugging it).
rabenoja
Copper - Posts: 61
Posted: May 18, 2004 at 9:37 PM / IP Logged
you can do what johnmax said.  Just undo the 4 bolts (10 mm, I believe) and lay on the ground.  You might have to take off the plastic panel to the left of the knee bolster to get the airbag to lay flat on the floor.  I've done a few of these already.
securinu
Silver - Posts: 772
Posted: May 18, 2004 at 9:59 PM / IP Logged
04 pacfica has a knee airbag nice design airbag sandwhiched between 2 steel plates . It must be noce to have a steel plate slam into your knees. Kia did this back in mid 90's with the sportage .
Joe O'Byrne
Owner / Installer
mxxmikexx
Silver - Posts: 796
Posted: May 18, 2004 at 10:12 PM / IP Logged
so whats the theory behind sandwiching an airbag between two steel plates? becoming an amputee instead of breaking your knees? seems like a fair trade....05 caravan knee cluster airbag -- posted image.
WillTS
Copper - Posts: 65
Posted: May 19, 2004 at 2:58 PM / IP Logged
Never seen one deployed, glad I don't have them05 caravan knee cluster airbag -- posted image.
Will              Just my $00.02
97 Chevy K1500 5.7L w/ Clifford Matrix RS2
BTW I am not a professional(well at procrastination maybe)
Be Gentle, I'm new to this :-)
