Retained Accessory
hawkinstaller02
Member - Posts: 44
Posted: May 18, 2004 at 12:38 PM / IP Logged
anyone know how to add a retained acc. for radio to remain on until the dor opens????????????
Did that work???????
-Installer-
profuse007
Gold - Posts: 2,015
Posted: May 18, 2004 at 1:57 PM / IP Logged
If you wish to keep the radio (or any other device that is powered by an accessory circuit) on until a door is opened, you can do so by creating a latch when the accessory is turned on with the relay shown below on the left, then breaking ground to the latch when a door is opened as shown with the relay below on the right. While this will keep the radio on, the entire accessory circuit will see 12V+ until a door is opened with the key in the off position.(the12volt.com @ relay section)
Retained Accessory -- posted image.
Houston,TX
WillTS
Copper - Posts: 65
Posted: May 18, 2004 at 5:38 PM / IP Logged
Would you be able to use a diode between the radio and the rest of the vehicle wiring to keep the juce from flowing to the rest of the accessories?
Will
