1995 toyota land cruiser
A & E Audio
Member - Posts: 8
Posted: May 19, 2004 at 9:22 PM / IP Logged
trying to install a remote start alarm in a 1995 land cruiser wont turn over alarm book says something about toyotas having a "ignition (2) on through cranking wire. diagram says that BLACK/ green is ignition #2 but this does not work?????? help please......
mark mcj
Member - Posts: 19
Posted: May 19, 2004 at 9:47 PM / IP Logged
If the starter won't turn at all it sounds like the starter wire isn't getting 12 volts. My referance showes the starter as being black with a white strip.
mark mcj
A & E Audio
Member - Posts: 8
Posted: May 19, 2004 at 9:52 PM / IP Logged
sorr the starter is turning ut the car wont start. it seems like the fuel pump kay not be comming on or something to that effect..
raydawg357
Silver - Posts: 769
Posted: May 20, 2004 at 1:30 PM / IP Logged
12volts black - WHITE/ red   +  ignition harness
Starter BLACK/ white   +  ignition harness
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition blk/grn or blk/red   +  ignition harness
Third Ignition
Accessory blue/red   +  ignition harness
Second Accessory
Do it right the first time
mark mcj
Member - Posts: 19
Posted: May 20, 2004 at 10:16 PM / IP Logged
1995 toyota land cruiser -- posted image.This should do the job. I was pretty warm today and now I have consumed several adult beverages. If anyone sees a screw up feel free to speak up.
mark mcj
mark mcj
Member - Posts: 19
Posted: May 20, 2004 at 10:31 PM / IP Logged
Sorry for the confusion. I posted this reply in the wrong topic. LOL!!
mark mcj
Platinum - Posts: 12,488
Posted: May 20, 2004 at 11:00 PM / IP Logged
Check to make sure that your getting 12 volts on your starter output wire from the remote starter first. Next, make sure that your ground is secure and free of dirt, grease and paint.
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
