turning radio on with extra output
jaxon23
Member - Posts: 25
Posted: May 21, 2004 at 7:18 PM / IP Logged
i have on the way the Ungo SR5000 and i am adding the DEI 530T and also a trunk selinoid. i believe the alarm has to outputs....what would i need to where i could push a button and my stereo system would come on and stay on?
profuse007
Gold - Posts: 2,015
Posted: May 21, 2004 at 7:29 PM / IP Logged
i think youve used it up already. one for the 530t and one for trunk, isnt it?
Houston,TX
jaxon23
Member - Posts: 25
Posted: May 21, 2004 at 7:31 PM / IP Logged
ok....well incase i change my mind on the trunk...how would i go about it?
profuse007
Gold - Posts: 2,015
Posted: May 21, 2004 at 8:46 PM / IP Logged
you need a channel that has a latched trigger. i know DEI product has this option w/ a channel thats program to latch and reset when ignition on.
Houston,TX
iskidoo
Silver - Posts: 1,046
Posted: May 22, 2004 at 11:19 AM / IP Logged
What is going to turn the radio off before it kills the battery? If you accidentally push the button in your pocket and the radio turns on you'll drain your battery. Does the vehicle have the RAP (retained accessory power) feature? What is the vehicle your installing into?
jaxon23
Member - Posts: 25
Posted: May 22, 2004 at 12:16 PM / IP Logged
its going into a 1998 Mitsubishi Eclipse Spyder. it was just a wow factor i wanted to get...my friend had it on his clifford alarm to where he could turn it on..i was just considering it
WillTS
Copper - Posts: 65
Posted: May 24, 2004 at 8:49 AM / IP Logged
You would hook a relay up to the output on the alarm, and then have it power the switched power that goes to your radio. Something like this.
86 and 87   12v+ Constant
30           Switched Power Supply to radio
85           - neg trigger from alarm
Now that would be if it has a latched trigger, if not you would need to add the latching part with some relays. Good info to be had HERE
Will              Just my $00.02
97 Chevy K1500 5.7L w/ Clifford Matrix RS2
BTW I am not a professional(well at procrastination maybe)
Be Gentle, I'm new to this :-)
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
