keypad removal
scrib2s
Posted: May 22, 2004 at 10:46 PM / IP Logged
to start my truck, 1990 toyota pickup, i have to type in a code on a keypad before it will turn over, i want to remove it but dont kno how, when i lloked at it the keypad connects to a small black box, and out of the box there is several wires that come out and go to ignition and other places. i was told that the it interupts the wire from the ignition to the soleniod im not sure what im have to do to find  and connect the wires to get rid of the keypad. any advise to help me figure out how this works or just simply what i need to do to remove it will be appreciated.
draasch
Gold - Posts: 2,172
Posted: May 22, 2004 at 10:54 PM / IP Logged
you should be able to trace the wires from the unit to the connection point....if you find any wires that were cut in two, reconnect them and that should take care of everything...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
