2000 sonoma alarm/rem start
1badnotch
Member - Posts: 15
Posted: May 24, 2004 at 12:16 AM / IP Logged
i am in the process of installing a viper 800 esp alarm with a your valet 551t REMOTE STARTERin 2000 gmc sonoma and have a few questions here goes
1. do i need to wire the starter kill relay because my vehichlie is equiped with gm passlock 2
2. on the 551t it has secondary ignition what is this does it need to be hooked up
3. on the 551t relay pack the is a fuse holder what amp fuse goes in there
4. it says i need a dei 555l or 555t can i buy this at any stereo shop and where does it install on the alarm/ remote starter?
thanks in advance
ERIC
draasch
Gold - Posts: 2,172
Posted: May 24, 2004 at 7:46 AM / IP Logged
1. its always good to have an extra one just in "case"...
2. it wouldnt hurt to power it up....
3.i dont use that unit...what is the relay pack for???
4. im not sure what the parts are for, but you should be able to get most DEI products at any shop...now how much will you pay for it....some shops charge an arm and a leg.....shop around first.....get all you parts together then do the install....if you dont and you really need the part, well you will pay top dollar....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
1badnotch
Member - Posts: 15
Posted: May 24, 2004 at 12:05 PM / IP Logged
it is the external relays where all the heavy starter wires come from
1badnotch
Member - Posts: 15
Posted: May 26, 2004 at 12:55 AM / IP Logged
anyone else know about these units???
1badnotch
Member - Posts: 15
Posted: May 26, 2004 at 8:35 PM / IP Logged
ok heres another question
do i have to use the channel 3 output from the viper to activate remote start?
or can i use channel 4,5, or 6 as long as i use the sensor shunt input (BROWN / black) used to bypas sensors during remote start???
