Stock Alarm Going Off Like Crazy
Thuan
Copper - Posts: 88
Posted: June 03, 2004 at 5:34 AM / IP Logged
earlier today i removed the fuse for the ecu out of my girls 92 acura integra gsr...after i replaced the fuse the alarm goes off non stop..so i disabled the alarm by unplugging the fuses to the alarms power and ground...now the car is without a working alarm. it was working fine before but by any chance would anyone know how to get the alarm to function properly or what could be causing this?  thanks
Thuan
onlyremotes
Member - Posts: 21
Posted: June 03, 2004 at 9:35 AM / IP Logged
What is the fcc# from the back of the remote(s)? How many buttons?
Walton Guerrero-Installer/Distributor
Alltech Electronics,Inc
3732 Grissom Lane
Kissimmee, Florida 34741
autotechs.com onlyremotes.com
1-888-252-8324
"Always check your wires with a multimeter"
Thuan
Copper - Posts: 88
Posted: June 03, 2004 at 4:54 PM / IP Logged
FCC ID:H5LAL777A
(2) Buttons : button #1 -  to turn the alarm on/off with sounds
                       button #2 - to turn the alarm on/off without sounds
any help would be appreciated...thanks
Thuan
JWorm
Platinum - Posts: 2,208
Posted: June 03, 2004 at 8:04 PM / IP Logged
A 1992 Integra doesn't come with a factory alarm. Can you read the model number off the alarm brain?
auex
Platinum - Posts: 5,041
Posted: June 04, 2004 at 12:20 AM / IP Logged
Well, it is made by Tekstar Corporation out of what looks like japan. Does it have a large button on the left and a smaller button on the right?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Thuan
Copper - Posts: 88
Posted: June 04, 2004 at 7:09 AM / IP Logged
both buttons are the same size....one is labeled I and the other II. i guess it doesnt come with a stock alarm but its sure acting like one.
Thuan
profuse007
Gold - Posts: 2,015
Posted: June 04, 2004 at 8:02 AM / IP Logged
so the remote doesnt do anything when you press the button(s)?
Houston,TX
Thuan
Copper - Posts: 88
Posted: June 04, 2004 at 4:09 PM / IP Logged
yeah, the remote doesnt do anything when i press the buttons....the light just lights up. still unable to get it to arm/disarm the vehicle. sometimes i can get it to arm the vehicle but i cant disarm it...funny shi*...well not too funny cause its stressin' me out but yeah.
Thuan
onlyremotes
Member - Posts: 21
Posted: June 05, 2004 at 10:29 PM / IP Logged
You need a new remote. What is the board# inside the remote? There may be a white sticker with a code on it.
Meanwhile put the alarm in Valet mode
3732 Grissom Lane
1-888-252-8324
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
