508d install question
nseck
Member - Posts: 7
Posted: June 08, 2004 at 12:26 PM / IP Logged
I have the viper 791xv and I do not know where to plug in the  508d's wiring harness. There are no plugs left does the 508d pug into the slot where the shock sensor goes or not on the viper module. thanks for your help
Ashez
Member - Posts: 26
Posted: June 08, 2004 at 4:22 PM / IP Logged
You gotta tap the wires from the 508 to the wires for your shock sensor... I dont remember how it is exactly, but I'll try to find out for you...
zargon
Copper - Posts: 186
Posted: June 08, 2004 at 6:13 PM / IP Logged
i think you tie the two wires together from the 508d and tie the twowirestogether fromthe shocksensor and run the two from the shock sensor tothe blue wire and runthe two from the 508d to the green wire
zargon ruler of estranorth
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
