Parking light wire on 2000 Eclipse
ajiuo
Posted: June 12, 2004 at 8:58 AM / IP Logged
I hooked the alarm up and everything works great but I can not find the (+) parking light wire. The Wiring diagram for the car tells me it is a grn/wht or pnk/blk wire under the driver kick panel.
Does someone know if it’s on a particular connector?
Platinum - Posts: 12,488
Posted: June 12, 2004 at 9:05 AM / IP Logged
The wire will be LOW in the driver's kick panel. When it says LOW that means it's under the carpet somewhere behind the panel under everything Parking light wire on 2000 Eclipse -- posted image. If you can gain access to one of the switches that illuminate, then use the light wire from there. It's the same thing.
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
