591xv-455j
Lubrano
Copper - Posts: 113
Posted: June 12, 2004 at 6:00 PM / IP Logged
I am installing a 591XV remote start and am using the 4555J interface and am running in to problems.  Confused as to which wires on the brain connect to the interface.  On the interface There is :
red:   12VOLT (easy)
black:  ground (easy)
BLACK/ white:   -3 second pulse (not used no security just start)
green:  green on brain  arm/lock input
blue/white:  ??????????????????????????  -disarm driver unlock input
blue:  ??????????????????????????????  -disarm all doors unlock input
blue/black:  ??????????????????????????  - input from remote start
yellow? black:  data wire on diag plug   yellow/black or yellow/violet
Thanks to everyone
JWorm
Platinum - Posts: 2,208
Posted: June 13, 2004 at 1:39 PM / IP Logged
The manual is really clear on all of these things.
blue/white - H4/3 (pg 12 in manual) blue wire
blue - H1/6 (pg 10) blue wire
blue/black - blue (-) 200 mA Status output (bottom page 12)
yellow/black - to the yellow/black or yellow/violet wire at the OBDII diagnostic plug under the dash.
