1986 VW Jetta, Thor Alarm
veedubs
Posted: July 10, 2004 at 11:33 AM / IP Logged
First off the vehicle I am refering to is a 1986 VW Jetta the wiring diagram is here is that will help. 1985-92 Volkswagen Jetta Alarm Information
The alarm that I am refering to Is a Thor alarm with a paging unit and such its a no name alarm lets just say!
For the Remote start on this alarm I am having troubles trying to figure out how to wire it to my car. Here is a link to the wiring diagram  http://members.shaw.ca/phillips15895/remote%20start.JPG.
The only two wires I can't figure out is the Key on and the power supply to the starter, I am not to sure where to find those wires.  Is it the "starter" RED / BLACK one on the wiring diagram for my car? And is the "Key On" the Ignition wire Or will is be the "accessory"?
Please help me out!!!
draasch
Gold - Posts: 2,172
Posted: July 10, 2004 at 10:29 PM / IP Logged
the first one is the starter wire and the second one is the ign. wire....
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK IGNITION SWITCH HARNESS
Starter RED / BLACK IGNITION SWITCH HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
