Ignition 2
meh66
Copper - Posts: 266
Posted: July 11, 2004 at 5:57 PM / IP Logged
I have another question, I also found out that the 91 Mx do not have an ignition 2 wire as indicated as GREEN / WHITE per the wiring diagram, but I have a question. Could I connect the igniton 2 from the alarm module to the cold start wire which is BLACK/ green or GREEN/ red or should I just use the one starter wire from the alarm with or without additional relays?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
kgerry
Platinum - Posts: 3,455
Posted: July 12, 2004 at 2:10 PM / IP Logged
no you want to use a relay off the existing crank wire...you dont want that circuit powered all the time, only during crank
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
meh66
Copper - Posts: 266
Posted: July 12, 2004 at 3:40 PM / IP Logged
will do....thanks I was not even looking at that.
MEH66
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
