Remote Starter & Door Locks not working
beslt
Posted: September 11, 2002 at 3:15 PM / IP Logged
Hello I installed the Buldog RS102e remote starter and have a 1995 Jeep Grand Cherokee.  Everything works accept locking the door locks.   I can unlock  the door and even lock and unlock while the vehicle is running.   But is the vehicle is not running than unlock is the only time it works.
Any suggestions.
Tong
Member - Posts: 9
Posted: November 22, 2002 at 1:37 AM / IP Logged
HI,
Sorry can´t help you butI I have a question for you!
 what signal did you use? tach or alternator, and what was the colour?
We have a -94 and can´t find the alternator cabel for remotestart.
tong
jrilla
Gold - Posts: 1,498
Posted: November 22, 2002 at 5:37 AM / IP Logged
Tong Look for a Gray/Blue wire at the PCM which is high on the passenger side firewall under the hood.
Beslt: Sounds Bizarre to me, what wires do you have tapped into and how did you do it?
J Rilla
Owner/Installer
cpgoose
Gold - Posts: 1,098
Posted: November 25, 2002 at 7:38 AM / IP Logged
hey beslt, you should try calling Bulldog Tech Support, they're pretty good.  I've called them a number of times, and they've helped quite a bit.  800-878-8007
