Remote Start
meh66
Copper - Posts: 266
Posted: July 14, 2004 at 11:32 AM / IP Logged
Should the remote start function work if you have not completely wired the alarm such as the door lock, triggers?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
Moderator - Posts: 12,488
Posted: July 14, 2004 at 11:51 AM / IP Logged
Depends on the system. Some require the doors to be hooked up so the system knows that all doors are closed ( mostly on manual transmission remote starter units ). What system do you have ?
meh66
Copper - Posts: 266
Posted: July 14, 2004 at 12:48 PM / IP Logged
I have the Crime Stopper 2015FM
MEH66
Posted: July 14, 2004 at 1:44 PM / IP Logged
The install manual says nothing about the door trigger's required for hook up for remtoe start sequence, so I'm guessing that your good to go without having to hook up these wires in order for the remote start to operate.
meh66
Copper - Posts: 266
Posted: July 14, 2004 at 10:36 PM / IP Logged
ok...thanks
MEH66
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
