fuel pump fuse blowing
bigj2309
Member - Posts: 6
Posted: July 17, 2004 at 9:13 PM / IP Logged
I have freind with a 95 chevy lumina van.  It had an alarm installed in it but some one took it out.  Now when ever she shuts the car off after driving the fuel pump fuse blows.
I thought it might have something to do about the security system (ie passlock or something like that) contributing to the problem.  I have already replaced the fuel pump and the injectors.  Though it is running better it still blows the fuel pump fuse when you kill th engine.
bigj2309
auex
Platinum - Posts: 5,041
Posted: July 17, 2004 at 11:55 PM / IP Logged
It only blows the fuse after the engine is shut down, not when driving or starting?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
bigj2309
Member - Posts: 6
Posted: July 18, 2004 at 11:12 AM / IP Logged
Right, only after the car has been running, not while starting or driving.
bigj2309
Teamrf
Gold - Posts: 1,031
Posted: July 19, 2004 at 8:07 AM / IP Logged
You may want to trace that wire. Maybe just replace it, or take out the passlock on it-and get an alarm.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
bigj2309
Member - Posts: 6
Posted: July 19, 2004 at 5:06 PM / IP Logged
I am not sure if it has a passlock on it or not.  If so it could be the root of my problem.  I thought it might be an electrical short but every time I put a fuel pump or injectors on it, it didn't blow the fuse for about a month then slowly worked back into blowing the fuse every time you shut the motor off.
I am really confused and would like for someone to point me in the right direstion.
bigj2309
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
