Replacing single stage, with dual stage..
TheBayArea
Member - Posts: 26
Posted: August 07, 2004 at 5:18 PM / IP Logged
Can anyone help me out with changing my single stage shock sensor, to a dual stage shock sensor? My alarm has an input for a single stage shock sensor with only 3 pins. When I bought the alarm, the person didnt tell me that he broke the shock sensor, and he wouldnt be able to provide me with one. I do however have a dual stage shock sensor from another alarm that I want to use.
Does anyone know how I can find out which pin from the alarm does what? Is there a way for me to find out from the shock sensor, which wire is which? The shock sensor is from a Crimestopper alarm, with 4 pins: Red, black, blue, and white.
Let me know if you need more info. Thanks ahead of time!
draasch
Gold - Posts: 2,172
Posted: August 07, 2004 at 5:44 PM / IP Logged
the white is (i beleive the first stage). you will not need that wire....you will only need the red,black and blue.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
TheBayArea
Member - Posts: 26
Posted: August 07, 2004 at 6:51 PM / IP Logged
So which wires go where to the alarm?
draasch
Gold - Posts: 2,172
Posted: August 07, 2004 at 7:10 PM / IP Logged
the blue on the shock will go to the neg trigger wire....ie hood/trunk
Good Luck
David
Ace Security
813-376-9778
Tampa
