Problem with diode
Jimichonga
Posted: August 25, 2004 at 1:30 AM / IP Logged
I have a 91 bmw with separate L (+) and R (+) parking light wires coming off the light switch. I'm installing a Code CA-640. The parking light out from the alarm (+) does not need a relay. But code says to diode isolate. The diagram below shows how I wired it up. It all works fine but my problem is the diodes get very hot when they are triggered. I'm not sure what the rating is on the diodes, I got them from a local car audio shop. I told them I need diodes for my bmws parking lights and they gave me a couple. I'm not sure if I wired it wrong or if I got the wrong diodes. I did check the amperage draw of the parking lights and it was around 3.5
Problem with diode -- posted image.
jaxman
Copper - Posts: 185
Posted: August 25, 2004 at 3:36 AM / IP Logged
Use MINIMUM 5A Diodes.
Damn cold here ...Problem with diode -- posted image.
draasch
Gold - Posts: 2,172
Posted: August 25, 2004 at 8:51 AM / IP Logged
use two relays or a 6 amp diode
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Teken
Gold - Posts: 1,492
Posted: August 25, 2004 at 3:41 PM / IP Logged
The 6 ampere diode you require is a D620. It is rated for 6 amps, and has a working voltage of 200 volts.
Regards
EVIL Teken . . .
Jimichonga
Posted: August 25, 2004 at 4:13 PM / IP Logged
Thank you guys, I picked up some 6 amp diodes today rated at 50v. I'll see if that works. Thanks again.
