Hidden switch to open door
NiiAddy
Member - Posts: 14
Posted: August 30, 2004 at 1:21 PM / IP Logged
My alarm remote has a tendancy to not work at times and as i have no key locks on my car, i often get get trapped.
I want to wire a switch directly to the solenoid in my door so i can at least open the door.
I have a 5 wire solenoid, what is the best way to wire up the switch.
kgerry
Platinum - Posts: 3,455
Posted: August 30, 2004 at 1:27 PM / IP Logged
and were do you plan to put this switch? on the outside of your car?   or are you talking about being locked in the car?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
NiiAddy
Member - Posts: 14
Posted: August 30, 2004 at 1:30 PM / IP Logged
yeah on the outside, hidden somewhere. i'm getting locked out of the car.
mo12v
Posted: August 30, 2004 at 2:21 PM / IP Logged
There are Pressure, Magnetic, Touch, etc. switches U could probably use. It would depend on your personal preferences.
Or U could put a CHEAP Keyless Entry  on (maybe even used,   A lot of Stereo shops get old stuff they have to take off)  and be done with it
MO
sparkie
Platinum - Posts: 2,061
Posted: August 30, 2004 at 3:52 PM / IP Logged
A trick I used to use for applications like this was to use a magnetic reed switch inside a tail light. Stash the magnet that comes with the switch behind the gas filler door. You need a normally open switch. If you have aftermarket door locks, there should be a lock and unlock trigger on the module you can use the reed switch to activate. The beauty of the system is that weather shouldn't be a problem and you don't run the risk of someone finding the hinden switch.
sparky
another-kelly
Silver - Posts: 618
Posted: August 30, 2004 at 4:09 PM / IP Logged
NiiAddy
Member - Posts: 14
Posted: August 30, 2004 at 4:12 PM / IP Logged
The reed switch looks like the way forward. I have a clifford but is there a way i can bypass the alarm and link directly to the solenoid.
I'm assuming a pulse sent to one one the wires would unlock, which one though?
mobilevt
Copper - Posts: 73
Posted: August 30, 2004 at 11:20 PM / IP Logged
You just had to be smart eh?  That is just flat out smart & clever!!! Hidden switch to open door -- posted image.
Emergency Vehicle Technician
Got Freedom? Thank a vet!
NiiAddy
Member - Posts: 14
Posted: August 31, 2004 at 12:28 PM / IP Logged
Any ideas
swamprat323
Gold - Posts: 1,335
Posted: August 31, 2004 at 5:39 PM / IP Logged
Tap Magic
Here check this out works great for people who lock there keys inside.
Aslo may want to look for a new remote.
