factory car alarm
dazed
Member - Posts: 22
Posted: September 24, 2002 at 1:13 PM / IP Logged
I have a '93 MX-6 and it has a factory alarm and a Chapman.  Problem is that sometimes when I unlock the door (no remote entry) the factory alarm goes off.  Anyone know how to disable alarm without disabling the starter?  I should still be able to use the Chapman, which I have switched off at present.
dazed
securinu
Silver - Posts: 772
Posted: September 24, 2002 at 2:03 PM / IP Logged
there is a yellow / red wire in the drivers kickpanel just ground this wire possibly thru a toggle if you want to use it later then you wont have to tear off the kickpanel again.  good luck.
dazed
Member - Posts: 22
Posted: September 25, 2002 at 6:42 AM / IP Logged
Thanks for your help securinu......I will do this as soon as possible.
dazed
