Piezo Siren Add-on to Siren with Chirp
logem
Posted: September 30, 2002 at 12:27 PM / IP Logged
I just finished installing an Alpine SEC-150R in my Jeep Wrangler.  I want to add a piezo siren under the dash.  After reviewing previous posts, it seems that the best way is to tie into the siren output with a relay.  My question is:  If I do this will I eliminate the soft chirp feature of the system?  Is the soft chirp produced from a lower voltage output than when in full alarming mode?  If I power both sirens (Alpine & piezo) with the relay, then they will get a full 12 volts everytime.
The siren output on the Alpine is 2 amps.  I have purchased an inline 2 amp fast acting fuse, and am considering just wiring both sirens directly to the alarm output.  If the fuse blows, then I know that they will draw more than 2 amps, and that I will have to use the relay.
Any ideas on how the soft chirp works?  And will I eliminate this feature with a relay?
BTW, I admire all of you installers.  Although I managed the install and feel that I did a "professional" job with all wires taped and loomed to look factory, It sure was a total pain and took LOTS of time.  I should have paid the $130 for an install.  At least I learned alot.
the12volt
Administrator - Posts: 3,959
Posted: September 30, 2002 at 1:04 PM / IP Logged
Hi logem, yes, the best way is to use a relay on the siren output. You can leave the Alpine siren connected as it is now and connect terminal 85 of an SPDT relay to the (+) siren output of the alarm. Connect terminal 86 to ground. Connect terminal 87 to constant 12V+ with a 5 amp fuse and connect terminal 30 to the positive lead of your additional siren. Connect it's negative lead to ground.
the12volt
logem
Posted: September 30, 2002 at 1:12 PM / IP Logged
the 12volt,
Thanks.  I'll do that.  The relay and Alpine siren shouldn't  exceed 2 amps (I hope).  I'll fuse it for safety.
Mike L.
carguy411
Silver - Posts: 683
Posted: September 30, 2002 at 5:38 PM / IP Logged
i read on the mini peizo sirens that you dont need a relay. i have a crimestopper alarm do i need to add a relay.just makin sure
thanks
the12volt
Posted: September 30, 2002 at 5:50 PM / IP Logged
Some alarms may be able to handle more than one siren connected directly to it's output, but it's always a good idea (good habit) to add the relay .
the12volt
Hi Mike, you're welcome. Glad I could help.
