92 Buick riviera audiovox
savo
Member - Posts: 8
Posted: October 12, 2004 at 2:42 PM / IP Logged
I am trying to install a Audiovox AArs30cs Rev.00 into a 1992 Buick Riviera. I have installed Remote starters before. But they were simpleler cars and simpleler Units. ie Bulldog security on a 91 Geo Prizm. This is my first complex install for someone, I would not like to break it.
Has anyone installed these before? Has anyone installed a remote starter in this car before? Is there anything I should know before starting?
--savo
mo12v
Posted: October 12, 2004 at 3:10 PM / IP Logged
U thought U had fun back then,  This will be even more fun
Be sure & get as much info first and READ everything
This is what I have:
Constant 12 voltsRED / WHITE AND 3 REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITE (-)DRIVER PIN SWITCH OR COURTESY LIGHT
Trunk Pin SwitchLIGHT BLUE (-)DRIVER PIN SWITCH (ALSO COVER DOORS)
Parking LampDARK BLUE(+) HEADLIGHT SWITCH OR AT RELAY
Power LockLIGHT BLUERELAYS IN DRIVER KICK PANEL
Power UnlockBLACKRELAYS IN DRIVER KICK PANEL
Positive Pulse Door Lock
Accessories
Window UpD\ D BLUE P\ D BLUE/WHITE @ MAIN SWITCH
Window DownR/ BROWN S/ TAN
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
Trunk ReleaseBLACK(+) AT RELEASE SWITCH
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsLIGHT BLUE (+)AT HEADLIGHT SWITCH OR AT RELAY
OEM Alarm ArmLIGHT BLUE (-)DOORLOCK RELAY
OEM Alarm DisarmLIGHT GREEN (-)KEYLESS ENTRY MOD. OR DRIVER KICK
 Reversal Rest At Ground Power Window Circuit Diagram.
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITECONTROL MODULE OR AT DISTRIBUTOR
Ignition #2D BLUE/WHITEIGNITION SWITCH HARNESS *
Ignition #3ORANGEIGNITION SWITCH HARNESS *
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK SWITCHON TRANSAXLE (91 ONLY/92-93 N/A)
Brake LightLIGHT BLUE (+)SWITCH ON BRAKE PEDAL SUPPORT BRACKET
Reverse LightLIGHT GREEN (+)GEAR SELECT SWITCH ON TRANSAXLE
Rear Window Defrost
* There Are 4 Ignitions To Be Powered By Remote Start Unit. Ignition #1- PINK (Primary Ignition). Ignition #2- ORANGE (Heat/ac). Ingition #3- D BLUE/WHITE (Engine Control Module). Ignition #4- PURPLE / WHITE (Heat/Ac).
MO
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
