Clifford rs3.5 matrix transponder alarm
webstar
Member - Posts: 17
Posted: October 18, 2004 at 12:56 AM / IP Logged
Hi
Any views on RS3.5 MATRIX alarm
I am thiking of installing one in the wifes MGF soft top  good or bad idea, the factory alarm is useless.
difficult to install ?
i seem to have managed ok with my intellivoice iq install on my coupe (Teken take a bow)  but the rs seems way more advanced.
Any advice would be more than helpful
webs
kgerry
Platinum - Posts: 3,455
Posted: October 18, 2004 at 10:05 AM / IP Logged
it's a nice unit, you'll want to go with the 508D FDS sensor as well if it's a soft top.......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 1:04 PM / IP Logged
What model year is this vehicle? I may be able to supply you with the required wiring schematic(s) for the vehicle.
If you also need the RS 3.5 installation guide please let me know, and I will leave a link here.
Also, you will find this installation easier, and more enjoyable, as the IG unit is pretty intensive in itself.
Regards
EVIL Teken . . .
webstar
Member - Posts: 17
Posted: October 19, 2004 at 1:05 AM / IP Logged
The car is a MG F  year is December 1999.
Do you need Cliffnet wiz pro for the RSX 3.5, oh i managed to find an install guide posted but its 57 pages and looks a bit daunting will have think it all through first .
I could send the wife on holiday just in case it goes wrong.
What is the 508D FDS sensor ? is like proxy 4 sensor.
webs
webstar
Member - Posts: 17
Posted: October 19, 2004 at 1:12 AM / IP Logged
Nice one guys car is a December 99 MG/Rover  F model or just MG F .
do i need Cliffnet wiz pro for the RS 3.5? oh i managed to find install guide posted, 57 pages looks a bit daunting may need to send the wife on vacation in case it goes wrong...
Whats the 508D FDS sensor ? is it like the proxy 4 ive got on the intelivoice iq.
webs
Teken
Gold - Posts: 1,492
Posted: October 19, 2004 at 5:54 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - ROVER / MGF (UK) / 1996 / Remote Start
12volts
Starter BLACK/ white      ignition harness
Second Starter
Ignition BLACK / YELLOW      ignition harness
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock pink   5wi alarm under centre console
Power Unlock orange   5wi alarm under centre console
Lock Motor
Unlock Motor
Parking Lights+ grn/wht & grn/red     alarm under centre console
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger violet/white    -   alarm under centre console
Dome Supervision
Trunk/Hatch Pin violet/red      alarm under centre console
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer BLACK/ white      left plug @ instrument clust
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Not Available
This is as close as I can get for you. Break out the meter to verify the rest of the circuits.
You do not need the Cliffnet Wizzard Pro, but having the proper cable and the software does enable you to do extra features which are not accessable via the valet switch. A 998 Bitwriter will also do the same thing, and does speed along the programming sequences.
With respect to the RS portion. Yes there are more wires to interface, but again, taking the proper time and preparations to have all available information and resources at hand will make it go smoothly.
The 508D FDS is like the Proxy 4, but alot less sufisticated, and reliable.
Regards
EVIL Teken . . .
webstar
Member - Posts: 17
Posted: October 20, 2004 at 12:46 AM / IP Logged
Thanks Teken
This will help loads
webs
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
